Thread: E36 location of modules and relais
    Default E36 location of modules and relais
    am trying to make a list for all, so pls help to complete it.
    Behind glove box (LHD car):
    ABS
    Airbag
    DWA (anti-theft device)
    window lifter
    window wiper-washing
    central locking
    Behind the battery (engine room):
    Transmission/gear
    DME (digital motor electronics/ECU)
    In trunk:
    Audio
    At the drive system for the sunroof:
    Sunroof relais
    The fuses and most of the relais are in the engine room, however some of the relais are also in the cabin next to the steering wheel column.
    Jun 2006
    KY
    where might the comfort relay be on a 1994 318is ? and what does it control?
    I bought a haynes book and it is a pathetic excuse for a manual and it shows six relays (one of which is comfort) above the left kick panel, well all I see there is one very large one.
    The reason I'm looking for it is I suspect maybe it runs the sunroof. I am not getting power to my red wire on my sunroof switch or the sunroof fuse. If I jump power to it the sunroof operates correctly. The book shows a "distribution box" and "distribution box b" is that the fuse boxes?
    87esir
    '94 318 113k miles, '69 chevelle, '65 fb mustang,
    Default try this
    Try the bentley manual. I have one for my 318is E36. I found it very helpful. A lot better than the haynes one which seemed to be little more than a service manual.
    Also there are some BMW CD's called ETM (electronic Troubleshooting Manual) these should help you locate modules and their function. It includes wiring diagrams and overviews etc. This was replaced with WDS (Wiring Diagram System for newer BMWs)
    Also BMW TIS might be helpful, BMW's EPC will also have cutaway drawings for everything
    shoulders
    As you have a Bentley, why do you not just check it out for him where the
    comfort relay is located?
    That is a very good idea. I should of thought about it.
    Anyway I have looked in the bentley and i think the comfort relay is to do with the central locking. It wasnt very clear what is did. It just said where it was and pointed to it in winring diagrams.
    "AUXILIARY RELAY PANEL - the auxiliary relay panel contains five relay posistions. In later models an additional fuse holder (fuse 48) and the EWS II (anti Theft) transmitter/reciever module are located on this panel. (see fuse layout picture)
    The panel is located next to the steering column under the drivers side dashboard. to access this panel, remove the lower dash panel on the drivers side. Then remove the drivers side knee bolster. lower the relay panel by gently releasing the plastic retainers. see fuse location picture.
    During installation, be sure the retainer tabs are engaged in the relay panel.
    hope this helps.
    Jun 2006
    KY
    thanks
  1. New General Modules (GM)
    Last Post: 09-17-2008, 12:08 AM
  2. locations of relais, fuses, ID tec. E32 series
    Last Post: 08-18-2008, 08:36 PM
  3. Advice on buying rebuilt modules
    By CrimsonBrian in forum 5 Series BMW
    Last Post: 06-12-2006, 03:58 PM
  4. Are E34 Climate control modules interchangeable
    By thruster87 in forum 5 Series BMW
    Last Post: 06-09-2006, 04:05 PM
  5. did the general modules ever change during production?
    Last Post: 12-24-2005, 08:02 PM
