Results 1 to 4 of 4
Thread: 89 535I steering problem
    Nr London
    Default 89 535I steering problem
    I was hoping somebody might be able to cast some light on my problem.
    My 535I's power steering sometimes locks solid (definately gets your attention) when turning right, usually when it is wet. Apart from this there is now a very bad vibration problem on the front end, which was cured before by new bushes, I'm sure this has something to do with the power steering as there doesn't appear to be any play elsewhere in the suspension.
    Any ideas will be much appreciated.
    Thanks Roger
    1/2 Way tween Chicago & Milwaukee
    Sounds like your power steering pump may have gone bad. But I'm no expert on the topic. Others may be able to provide better help. sorry, and good luck
    Default Since you say usually when wet, it makes me think that you're power steering pump-
    belt is old and loose or just loose.. and when the belt gets wet it slips so much that you lose your pump assist...Check tension on the belt first.
    Quote Originally Posted by Roger Hatfield
    Thanks Roger
    Default Additional wet info (m)
    does your power steering go out when you hit standing water? if so, you are missing the splash guard that is supposed to cover the underside of the engine bay. this prevent water from splashing on to components/pulleys, etc. I had the same issues until I realized I was missing that large cover for the underside.
  1. really scary steering problem - please HELP
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 12-06-2007, 06:28 PM
  2. Steering problem....Help please
    By Tony777 in forum 5 Series BMW
    Last Post: 09-12-2007, 06:49 PM
  3. Weird steering problem
    By IN10CT in forum 5 Series BMW
    Last Post: 12-31-2005, 07:24 AM
  4. steering problem (may be dangerous)
    By PABLO in forum 5 Series BMW
    Last Post: 09-01-2004, 11:48 AM
  5. Not the usual steering problem
    Last Post: 05-30-2004, 06:08 AM
