put some teflon tape on it temporarily if you need to drive it. Make sure you bleed the cooling system before driving it again cause the bleeder might have allowed an airpocket to form somewhere and it might overheat...cause a blown head gasket...other probs. DO NOT DRIVE IT IF THE TEMP NEEDLE GOES OVER HALF WAY!! shut off and drag home.
