Results 1 to 3 of 3
Thread: Ignition problem or fuel problem?
    Default Ignition problem or fuel problem?
    Hey guys,
    I have an intermittent problem. If I crank the key in the ignition and release the key key before the ignition fully fires, I am in big trouble.
    When I crank the ignition again, the car will start but act as if its choking and will die out unless I give it more gas. As soon as i let the gas go, it will die out again. If I keep gasing it at a high RPM(2000-2500RPM) for about a few minutes, it seems to pass and the car is fine.
    I can go for weeks without a problem, unless I forget to hold the key until the car fully cranks.
    I have pour fuel injector cleaner into the gas tank and also rerplaced the fuel filter.
    Any help would be great. I don't know if this is a fuel related problem or a starter component problem.
    Thanks
    old leaky fuel injectors ring a bell here.
    Default Looks like, I would run a pressure holding test in the rail.
    Javier
  1. Ignition Lock Removal Problem
    By bmwsed in forum 5 Series BMW
    Last Post: 01-05-2009, 02:52 AM
  2. I believe its a fuel problem
    By ber55ber55 in forum 5 Series BMW
    Last Post: 10-08-2006, 06:17 AM
  3. Some ignition problem i think!!
    By gothe86 in forum 5 Series BMW
    Last Post: 09-03-2006, 05:24 PM
  4. Fuel Delivery Problem
    By stargazer_61 in forum 5 Series BMW
    Last Post: 02-26-2006, 11:33 AM
  5. Variation of the ignition key lock problem
    By chapmanw in forum 5 Series BMW
    Last Post: 07-03-2005, 12:52 AM
