i use a can of carb cleaner if the idle changes you've found the spot, in v8 bimmers the problem spots are the seals at the front and back of the intake manifold, the 8 intake to head seals and the pcv plate on the back of the intake has a diaphram that fails, when we get a bad running v8 car in and a leak is found we pull the intake and do everything as it can all fail and cause problems
