Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 1990 535i Brake Bleeding nightmare
    Thanks for the procedure Bill. One question, during the 12 pumps, do I leave the engine on or off?
    furthest point and bleed first , typically the right rear wheel, then left rear then right front then left front. This should pretty much cover everything if you have any other questions let me know.
    Life is short.
    Default The engine is off while doing this.
    1
    Quote Originally Posted by xtmsports
    Bill.... it is possible to bleed the ABS if air gets into there with standarb bleeding procedure????
    Call me dumbass with this then. I HATE people giving false information and I have been the king lately if this is true.
    Bill, I tried Bruno's pressure bleeder and followed the instructions you supplied.
    All the wheels were fine except for the front driver caliper. Even though my wife stepped on the pedal 12 times with the bleeder open, it had a diffucult time coming out. Does that mean i need a new hose for the front driver caliper?
    Since it was coming out slow, I had my wife pump the brake 5 times and then held it down with some force, then I opened up the bleeder screw and brake fluid was forced through. I did this about 4-5 times. But I still feel a little bit of grabbing coming from the front driver caliper.
    Would you suggest that i need a new front driver brake hose?
    Life is short.
    Default Its possible that the brake hose has swelled internally but first i would
    try swapping the 2 front bleeder valves in case its a bad bleeder valve not letting the fluid out. If after you swap it then i would suspect a brake hose next.
  1. brake bleeding problems..........
    By duckloads in forum 5 Series BMW
    Last Post: 03-02-2008, 05:27 PM
  2. Brake Bleeding With ASC
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 09-12-2006, 12:46 PM
  3. One bleeding nightmare
    By Lennyz525i in forum 5 Series BMW
    Last Post: 01-16-2006, 03:19 PM
  4. HELP! Brake bleeding problem
    By Ted K in forum 5 Series BMW
    Last Post: 10-24-2004, 12:41 PM
  5. Brake bleeding on a 540i with asc.
    By wengenstein in forum 5 Series BMW
    Last Post: 09-15-2004, 05:33 AM
