Results 1 to 2 of 2
Thread: Control & Thrust Arm rubber boot failure
    Mar 2004
    Default Control & Thrust Arm rubber boot failure
    Has anybody else had bad luck with the rubber boots failing on their control and or thrust arms? I bought mine (Lemforder) 2 years ago, installed them and now after 30K miles I notice that the two on the drivers side are failed. Seems odd that they would fail so fast. And yes, one ball joint is bad (has some vertical movement which can be heard while driving). Kind of annoying since I expect these to last the life of the car. Rubber seems kind of dry as well - not pliable.
    Scott
    07 525i 22K, 07 328xi (41K)
    Feb 2005
    brisbane
    Quote Originally Posted by Scott C
    Scott
    the boots are not really a problem,
    you can always buy a new boot and re-pack it with
    bearing grease, but the end play in the ball joint
    like you said is not good
  1. %@#$% Lower control arms & upper boot
    By Asamaan in forum 5 Series BMW
    Last Post: 05-19-2009, 09:54 AM
  2. Where to find rubber boot for lock actuator
    Last Post: 05-18-2007, 06:52 PM
  3. With what to glue Intake boot rubber rings?
    Last Post: 11-05-2006, 10:54 AM
  4. Boot on upper thrust arm is broken- Replace?
    Last Post: 06-19-2004, 12:56 PM
  5. supra notes on thrust arm ball joints--boot source...
    Last Post: 05-01-2004, 07:07 AM
