Take the Idle control valve off. Fill it with carb cleaner and shake it around. Do this a couple of times - If you can't hear anything rattling around inside then the valve is probably smoked. Also check for vacuumm leaks, if there is any un metered air entering the engine the car will not idle. Jam a screwdriver in the throttle linkage to keep it running and spray carb cleaner around all the rubber bits and see if your idle changes. I bet you that while it was in astorage a hose collaped or was eaten by a rodent.
Good Luck !
