Results 1 to 3 of 3
Thread: Spinning window motor
    Los Angeles
    Default Spinning window motor
    More like cranks. It sounds as though the motor has broken free from the window. I had the door worked on by a body shop when someone scraped me a few years ago, so I figured I could take it in and have them fix it. However, if it's a 45 minute job, I'll do it myself and save the hassle. Has anyone ever dealt with this before?
    Dave
    dave b
    93 525i
    156k +
    Default Remember once my LH side rear door had something ...
    similar, and it was as simple as loose screws holding the motor into the window motor-gear.
    Just tight them all, and done!
    You should check it to see what is going on.
    Javier
    Mar 2004
    Brisbane, Australia
    my driver's motor and wind-up mechanism were making awful squeaking noises so i took the door trim off and greased it up as it was running dry. it took me about an hour all in to do the job. I'd do it yourself and save a bit of money. its not too difficult. just read up on how to take the door trim off.
  1. Can u service motor for winding down the window?
    By nsbone_1988_520i in forum 7 Series BMW
    Last Post: 04-23-2006, 04:21 AM
  2. How do i remove window motor ???
    By magicsid in forum 3 Series BMW
    Last Post: 03-12-2006, 08:40 AM
  3. Window Motor
    By mrbmw1 in forum 3 Series BMW
    Last Post: 08-25-2004, 06:45 AM
  4. @#$% Window motor. Idoit needs help
    By Andy in forum 5 Series BMW
    Last Post: 05-18-2004, 07:20 PM
  5. Is window motor replacement a DIY?
    By chris530it in forum 5 Series BMW
    Last Post: 04-15-2004, 08:20 PM
