Thread: m60 valve cover paint??
    Dayton, Ohio
    Default m60 valve cover paint??
    here is a picture of my valve cover with all the things (can't think of what they are called) removed... I'm going to do valve cover gaskets sometime soon, and probbaly the bolt gasket things too....
    but my question is, do you see all that crappy paint that is peeling off?? what should I use to repaint it??
    and in the process should I just sand down what loose flakes i can and put new paint over what I can't sand off? (by the time I do this my buddy may have a power washer, and I'm sure that'd make quick work of the busted paint)
    suggestions on color??
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    Hi temp spray paint... available at Home Depot... I'd suggest you use wire brush to get rid of rust... some navel jelly if necessary. Primer is excellent but read label first.
    Dayton, Ohio
    yeah.... wire brush!! didn't think of that...
    probably faster than sand paper too!
    Former: 95-530iM
    Dayton, Ohio
    Haha... I just ran across my first post (even before I was a registered member)
    http://www.bimmer.info/forum/showthread.php?t=4157
    it looks like the valve cover gaskets were done at 60 some thou.... and its now 70 thou later, looks like they are right on schedule to be replaced!
    Former: 95-530iM
    Houston TX
    won't be any rust...
    the metal on my 530i is slowly deteriorating...just flaking away...did sand and paint with high temp paint purchased at Auto Part store. Used he temp primer as well...be sure to read instructions as you may have to let the primer dry a few days before you spray top coat.
    Dayton, Ohio
    Quote Originally Posted by callen
    Dry for a few days!?!?!?!
    maybe I'll just skip the primer, I don't have that kind of patience
    Former: 95-530iM
  1. Replies: 2
    Last Post: 03-25-2009, 07:47 PM
  2. valve cover paint
    Last Post: 05-09-2007, 03:51 PM
  3. Valve Cover Paint
    Last Post: 12-05-2006, 04:52 PM
  4. Engine cover re-paint
    By andyman32 in forum 5 Series BMW
    Last Post: 10-15-2004, 08:05 PM
  5. Valve Cover Paint
    By hinchcliffe in forum 5 Series BMW
    Last Post: 05-10-2004, 07:41 AM
