Results 1 to 10 of 14
Thread: Polyurethane Engine mounts?
    Gainesville, FL
    Default Polyurethane Engine mounts?
    Does anyone make these for our car, or something similar to stiffen drive-train slack and whatnot. my engine flexes an unbelivible ammount when i rev it and watch with the hood open. I'm sure getting new OE mounts would improve it, but i'd rather just get something tough and soild.. especailly with those pesky P/S and oil leaks that will just destroy the OE ones again.
    more importantly, has anyone tried this or sees any reason i shouldn't? i don;t mind the vibration.. my V-8's meaty rythmic idle is nice i think...
    PA
    Quote Originally Posted by infinity5
    I'd like urethane mounts too. I know some people on this board are going to say that when you stiffen up a mount like an engine/tranny mount, you just displace the wear to another component. Personally, I'd risk it.
    Even if it were a hydraulic PU mount? I'd think it'd retain enough pliability to absorb the nearly the same amount of vibration.
    Honolulu
    Default D-D-D-Don't d-d-d-d0 i-t-t-t
    Poly-U is great for track and hard core drivers with a cast iron ass.
    If you are driving the car for comfort, than go with the OEM hydro-elastic mounts.
    Poly-U is not a choice on any comfort car engine mount; it is tough, but will transmit very bump, vibration and fart into the frame. Thus make the car fell very stiff and noisy.
    If your motor is tearing the mounts off the cross memeber, then set up a torque chain with a turn buckle to hold the engine & trans.
    Mar 2004
    Brisbane, Australia
    i've just started a new job in a place that makes polyurethane bushes and i was thinking about making some fit my car(engine mounts). they don't make anything for bmw's but i can get something similar and cut them to size. If i do go ahead with it i'll let you guys know what they're like. i don't care about a harsher ride or anything like that before anyone starts telling me the pros and cons.
    Honolulu
    Default I turned down
    some monster 4X4 poly-u bushings on a lath to replace some obsolete control arm busihings for a friend's nissan, wow it was a tight ride.
    You will feel the road for sure on the poly-u.
    Hold on to your pocket change
    Jan 2005
    Sicily
    Get mounts for a BMW diesel engine, they are stronger and built to last longer , diesel engines are heavier than gasoline ones.
    PA
    If you end up getting the PU mounts let me know. My car is already retardedly stiff and firm, it can't be any worse.
    Mar 2004
    Brisbane, Australia
    Obviously as a perk of the job i also get them for free so i'm going to replace ALL the suspension bushes etc with polyurethane ones when i get the chance. Was wondering if anyone has done this to their e34 yet and if so what are the results like? i've been in smaller lighter cars with PU bushes but i have no idea what to expect when my 5 has them in...will it really be a much harsher ride than stock? not that this worries me, as far as i see it the firmer the better but i'd like to know how much of an impact it has on a heavy car like ours. i need new thrust arm bushes anyway so they might as well be PU ones.
    PA
    Quote Originally Posted by Rory535i
    I am really interested in the PU motor mounts, duplicate a couple for me?
  1. Replies: 3
    Last Post: 02-27-2009, 08:08 PM
  2. Engine mounts ay...
    Last Post: 05-31-2008, 08:57 AM
  3. M60 engine mounts
    By e34musician in forum 5 Series BMW
    Last Post: 09-06-2007, 07:31 PM
  4. M50 engine mounts
    Last Post: 09-04-2007, 08:15 AM
  5. M60 Engine Mounts
    By stargazer_61 in forum 5 Series BMW
    Last Post: 07-02-2006, 07:51 PM
