Results 1 to 10 of 14
Thread: Car overheating - help!
    Default Car overheating - help!
    Just came back from a short spin and when I got home the temp gauge was at 3/4 and going north, I switched everything off just before it hit red. I looked under the hood and no obvious coolant leaks. The top hose was very hot and hard while the bottom hose was cold (not even warm) and hard.
    The waterpump was changed 15K ago (metal impellar) but the thermostat has never been changed.
    The car has 70k on the clock and had never run hot before.
    Any advice much appreciated!
    Don
    525iA '95.
    baton rouge, loserana
    id do the thermostat as it's probably stuck/broken
    Mar 2004
    Brisbane, Australia
    check the thermostat. Otto - German Car Parts Centre in Dublin sell good replacements. 01-497420. Mail order takes about 2 days.
    I thought about the thermo but if it was stuck open the I would have thought the car would take a long time to heat up which is not the case, if it was stuck closed the upper hose would not be hot (which it is!)....what do you think?
    stuck closed or you somehow got an air pocket in there. Try to bleed it and see if any air comes out, if not then you should do the thermostat.
    Mar 2004
    NSW, Australia
    Definitely a stat stuck closed but allowing just a trickle of hot coolant through.
    Quote Originally Posted by mamilapon
    Thanks guys, I will change the stat and let you know....
    Default Remember to drill a 2mm hole in the top near the arrow...
    Near where the arrrow points up, it'll help u to bleed the thing... u don't want to have to mess around... and u need an 80 degree thermostat for the 535- they cost $16 odd. GP
    Mar 2004
    Brisbane, Australia
    [QUOTE=genphreak]Near where the arrrow points up, it'll help u to bleed the thing... u don't want to have to mess around... and u need an 80 degree thermostat for the 535- they cost $16 odd. GP[/QUOTE
    not disagreeing or anything but is drilling the hole 100% necessary? i didn't do it to my new one and didn't have any problems???
    drilling the hole just about eliminates the chance for problems in bleeding, it's almost vital on m20 525s imho because there such a bitch to bleed, but it's not necessary
    [QUOTE=Rory535i]
    Quote Originally Posted by genphreak
  1. Overheating?! Not Again!!!
    Last Post: 07-23-2007, 10:53 AM
  2. Is your M50 overheating ?
    Last Post: 06-13-2007, 01:13 AM
  3. Overheating
    By uginer in forum 5 Series BMW
    Last Post: 12-25-2006, 12:39 AM
  4. car overheating, need help
    By misfortune in forum 5 Series BMW
    Last Post: 11-26-2006, 12:34 AM
  5. overheating
    By blaze12 in forum 5 Series BMW
    Last Post: 07-09-2004, 09:59 AM
