Thread: e60 center bore
    Feb 2005
    Richmond, TX
    Default e60 center bore
    I found out something today I didn't know. Did a search on here and didn't find anything so I thought I'd post it.
    I bought wheels from an e60 for my touring. I assumed the center bore was the same as an e39 so I also bought the hubcentric rings. Turns out with the e60 they went back down to the 72.6mm hub so e60 wheels bolt right on.
    This should mean more wheel choices available in the correct offset and center bore for the e34 as more manufactures start making e60 specific wheels.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2000 323iT - UUC BBK, PSS9 Coilovers
    2005 GMC HD Crew
    Yup -- the only 5 series (thusfar) to use a different hub size is the e39. Adam (Incantation) runs 18's from a uh...E60...as well, I believe.
    best, whit
    Yep that poor BMW engineer......can you imagine the added cost of having to inventory, on a global level, 2 part numbers for each wheel simply due to a mistake when spec-ing out the E39 hubs. I was told it cost BMW an additional $4million a year..needless to say, he has since been relieved of his duty.
    PA
    Quote Originally Posted by brodee
    Want to sell the centric rings?
    Feb 2005
    brisbane
    touring looks sweet!!!!!!
    Feb 2005
    Richmond, TX
    Not yet. I just bought some new wheels for my sedan and I'm going to hold out and see if I need them for it.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2005 GMC HD Crew
  1. MM hub bore
    Last Post: 11-22-2010, 08:46 PM
  2. Whats the hub bore on the E34?
    By swenpro in forum 5 Series BMW
    Last Post: 05-17-2008, 02:23 AM
  3. Replies: 11
    Last Post: 03-10-2005, 10:55 PM
  4. M30 big bore throttle body?
    By gale in forum 5 Series BMW
    Last Post: 02-10-2005, 02:13 PM
  5. V8 Nikasil bore problems
    By GJPinAU in forum 5 Series BMW
    Last Post: 02-13-2004, 12:43 PM
