Thread: Overheating M20
    Long Beach, CA
    Default Overheating M20
    Last Friday my 1989 E34 525i (M20) overheated in stop & go traffic. I let it cool and got more coolant in the system. Got it to a nearby mechanic. Monday morning they got the system full (Hopefully) and bled it (Hopefully). They the pressure checked it for 3 or 4 hours. No leaks. I've got a new thermostat in the sytem. He recommended that I change the fan clutch ($140.00 + labor). I checked with my brother and he told me to call BMA for the part (>$69.00 shipped). The mechanic didn't charge me for the pressure testing. We installled the fan clutch tonight. I'm thinking of doing a power flush and maybe a new water pump. I guess I just take it a step at a time, unless there are any suggestions.
    Nov 2004
    checking the cylinder head gasket might help... mine got toasted when the engine overheated...
    The thermostat still may (although it's a very unlikely MAY) be the problem. My car was overheating after installing a new Vernet tstat. After spending a week checking everything but it, I pulled it out and tested it (bring water to a boil in a pot with the tstat in it, observe what it does). I discovered that, although the tstat worked, I'd incorrectly placed a rubber gasket, which was preventing the tstat from opening (this was an m30 specific problem, though, IIRC).
    Before you spend the money on a fan clutch, see if it's "walking"/has normal resistance when cold. Also, check the aux fan and confirm that the sensor is working.
    How badly did the car overheat? Waaay above the 3/4 mark or ?
    best, whit
    Long Beach, CA
    Already installed the fan clutch (Only $68.78). Didn't quite get to the red, then came out the overflow. This morning was good, the real test will be this afternoon, with stop n go traffic and higher outside temperature.
    Long Beach, CA
    I'm trying to eliminate other possibilities before checking the head gasket.
    Long Beach, CA
    Well day one with the new fan clutch was a success. I'm closely monitoring the coolant level. I'm supposed to go to Palm Springs this weekend. We'll see.
  1. Overheating?! Not Again!!!
    Last Post: 07-23-2007, 10:53 AM
  2. Is your M50 overheating ?
    Last Post: 06-13-2007, 01:13 AM
  3. Overheating
    By uginer in forum 5 Series BMW
    Last Post: 12-25-2006, 12:39 AM
  4. car overheating, need help
    By misfortune in forum 5 Series BMW
    Last Post: 11-26-2006, 12:34 AM
  5. overheating
    By blaze12 in forum 5 Series BMW
    Last Post: 07-09-2004, 09:59 AM
