Results 1 to 10 of 17
Thread: Help! Blower/not the Sword & Overheating
    May 2005
    Tampa
    Default Help! Blower/not the Sword & Overheating
    Hate to post new thread on these items but its July in Hot FL. and I need help. Sword has been bad for awhile so I ordered new(used) one. Just before I got the new sword wife was driving and smoke came out the vent and blower stopped working. Don't think,(hope), blower is totally fried as it has come back on a couple of times since this happened and when it goes on it seems to work and sound fine. Anyway, put in new sword and nothing. Put old one back on and tried to activate it manually by moving the spring loaded piece,(sorry for lack of tech. names here), and nothing. Previously this would kick it right on and would see a tiny spark, now I'm getting nothing. Checked the fuse and its O.K. don't know where to check next. In addittion, a couple days after this happened she started overheating while at idle speeds, don't know if possibly connected to blower problem or if it is a tstat issue.
    Any ideas would be appreciated.
    P.S. sorry for long thread but, just spent $1000 at shop on the E36 and I'm determined to fix this myself
    Apr 2004
    Blower access easy. Pull cover on firewall at back of engine bay and check it out. Typical failure is bushings worn so bad that motor can't turn.
    Jul 2005
    Cologne, Germany
    overheating problem: M20 or M50 engine?
    greets from Germany,
    Kai
    A BMW is a black car with most rights in road traffic.
    May 2005
    Tampa
    Quote Originally Posted by Kai@e34.de
    Mine has the M20.
    Jul 2005
    Cologne, Germany
    does it still overheat? consumes coolant water?
    Kai
    May 2005
    Tampa
    Yes, so far I haven't rectified the overheating or blower problems. On the overheating issue, it doesn't appear to be consuming fluid and I have tried bleeding the system. I was wondering since the blower acts as a secondary cooling device and it isn't kicking on if that may be my problem, if not my current guess is the thermostat.
    Jul 2005
    Cologne, Germany
    no, your blower has nothing to do with that. it overheated only at idle speeds and not while driving? if so, check your fan coupling. additional to this, see if there's bright brown slime on the inside of your oil cover lid on the cylinder head cover.
    Kai
    May 2005
    Tampa
    No brown slime and fan is working.
    On a side note I'd love to come to your country and drive the Autobahn someday...... but first I've got to get my 5er back on the streets here.
    May 2005
    Tampa
    Quote Originally Posted by Gene in NC
    Took cover off and can see blower but, I have to admit not really sure what I'm looking for/at. Tried to turn on again and nothing so I tapped the blower w/ my flashlight and it started to work. Bad part is, I don't think it will last, it sounds like its struggling.
    Benneton (United Colors of)
    Quote Originally Posted by ck1995
    the blower is dead, the telltale is you getting it to restart it by hitting it. the brushes are likely too short, and by hitting it, you get them to make contact with the commutator again. if you don't know about electric motors, likely your only recorse is to buy another.
  1. is it the sword or the blower motor?
    Last Post: 02-24-2010, 05:06 PM
  2. Anyone have a good blower sword for sale?
    By Jeff N. in forum 5 Series BMW
    Last Post: 07-12-2007, 09:53 PM
  3. Blower is in and new connector on sword still no joy
    Last Post: 03-12-2007, 06:57 AM
  4. fan blower/sword question
    By nuwde in forum 5 Series BMW
    Last Post: 12-18-2005, 08:15 AM
  5. E34 blower problem and don't think its the sword
    By ck1995 in forum 5 Series BMW
    Last Post: 05-05-2005, 11:07 PM
