Results 1 to 3 of 3
Thread: Oil in air flow meter?
    Nov 2004
    Gateshead,UK
    Default Oil in air flow meter?
    OK, so I was checking my air filter the other day. It was as clean as the day I bought it in 18 months ago. I looked at the air intake "flap" and saw there was clean engine oil around it, and also in the black intake tube that goes to the inlet manifold. Somehow oil has been drawn up to the intake. How can this happen? I have an M20 engine by the way.
    Cheers,
    Shaun
    Quote Originally Posted by E34-520iSE
    Cheers,
    Shaun
    i wouldn't have a clue how oil got there. I assume your air filter is standard. Get a rag and clean that stuff off.
    West Palm Beach, South Florida
    Default Probably from the valve cover vent
    Its been awhile since I've had that stuff apart, but I know that the valve cover vent connects back up to the throttle body as do a few more hoses. My volvo has a crankcase ventilation system that gums up the throttle body like nothing else I've seen, but that wouldn't give you clean oil in there (not to mention that I don't believe our cars have that). If its clean oil, its probably coming from the tube that leaves the valve cover and goes into the air intake.
    Cheers,
    Shaun
  1. Air Flow Meter
    By SilverFive90 in forum 5 Series BMW
    Last Post: 07-07-2006, 09:01 AM
  2. Air flow meter
    By Jzza4 in forum 5 Series BMW
    Last Post: 05-12-2006, 08:14 PM
  3. losing power-air flow meter causing problems?
    By dreamer_bimmer in forum 5 Series BMW
    Last Post: 08-28-2004, 05:50 AM
  4. Air flow meter problems?
    Last Post: 05-13-2004, 03:52 PM
