Results 1 to 10 of 10
Thread: outer door handle gasket replacement info
    Default outer door handle gasket replacement info
    I bought 10 sets of the outer door handle gaskets from the source in Malaysia (dealer only sells the handle complete with the gasket) for some members of our E32 Club in Japan. Here are the info pics from my friend Mitsu, job done on his 750iL Highline.
    Remove the plug in the door, use flashlight to find the slider inside the door, push the slider forward towards front of the car, remove door handle from outside, replace and do same in reverse.
    It makes it easier to fit the gaskets snug when you let them warm up a bit in the sunshine or water, so that they are more flexible to install.
    Language Japanese, pics international
    http://infinitier.ddo.jp/e32/mainte_053.htm
    Jan 2007
    Dayton Ohio
    Default Is there an update on the door handle removal page
    Is there an update on the door handle removal page? I click on the link but got a bunch of gibberish. I just reglued my window in the track and notice that the locking actuator was gangling down. Looks like the actuator mound broke. it also looks like pot metal so I will need to find another one. Need to find out what it is called first.
    Ken
    Honolulu
    Default kowarichyatta
    dame desu nee
    Jan 2007
    Dayton Ohio
    Default Hello to you too
    Hello to you too
    Quote Originally Posted by Blitzkrieg Bob
    dame desu nee
    That helps
    http://www.bmw4life.com/doorHandle.htm
    Before you attach them, put them in warm water so that they get softer and
    fit easier.
    Jan 2007
    Dayton Ohio
    Default Thanks
    Thanks, this tuitorial is great
    Ken
    Ichi-ban-son
    Sep 2006
    Newnan
    got anything a little more detailed? The lever dosent exactly "push away from you" it moves from the left to right...
    When i tried moving this lever(both right and left) the handle never exactly "popped out" actually it didn't budge one bit.
    Anyone else with first hand experience have any more details on this?
    Maryland
    the "lever" slides... grab a flashlight and look for it after you remove the tiny oval access panel on the side of your door
    i believe you push it (away from you) to release the door handle cover --
    and use a hook to pull it to lock the door handle cover back into place.
    i did mine a few months back.. it really is simple.
    Sep 2006
    Newnan
    alright i figured it out, i was using too small of a screwdriver. Once i got a larger one, it did push in and release the door handle trim.
    Also, for those that end up doing this in the future, a paint can lid opener(free from home depot) works great as a hook mechanism to pull the lever back to the locking position.
    No. California
    Default Found that a paint key (used for opening cans) works
    really good for re-setting lever. The little hooked end is just the right size.
    Kurt 95 525ia
  1. outer door handle gaskets E34, E32, E36, Z3 - NEW
    By shogun in forum Swap Meet - Classified Ads
    Last Post: 12-30-2022, 03:57 AM
  2. Help: Outer door handle broken
    By bimmerred535i in forum 5 Series BMW
    Last Post: 07-10-2009, 08:43 PM
  3. outer door handle gasket installation instructions
    Last Post: 08-19-2008, 10:40 AM
  4. sticking outer door handle?- solution
    Last Post: 01-10-2008, 01:33 AM
  5. outer door handle gaskets in the U.K./Ebay
    Last Post: 02-09-2006, 10:16 PM
