Results 1 to 1 of 1
Thread: rough idle when parked on a incline
    Jun 2005
    Sammamish, WA
    Default rough idle when parked on a incline
    Joining this board now that I'm an owner of a 92 535iA with 118k. Waiting for the Bentley manual but have a problem that it probably won't answer.
    - When the car is already warmed up and idling while parked on a slight incline or decline. The car can idle roughly. It doesn't do this on a perfect level grade. Doesn't do this when the car is cold.
    Any ideas?
    == Update
    This problem is gone along with better mileage and more power by doing the following
    - Pulled the diag code and had a bunch of 1222s, I cleared the code by disconnecting the battery. I read in this forum that the engine management system will adjust based on stored fault code.
    - While tracing down an oil leak, cleaned the crank position sensor.
    One or both of these did the trick. No more check engine lights either.
    1992 BMW 535iA trying to become The Ultimate Driving Machine
    2001 Volvo V70 T5 ASR Our first Volvo. Wife says we are Volvo for Life
    Sammamish, WA
  1. Very rough idle, 92 525
    By aecs8284 in forum 5 Series BMW
    Last Post: 06-20-2008, 11:07 AM
  2. Coolant leak when parked on an incline
    By edward240 in forum 5 Series BMW
    Last Post: 01-11-2008, 04:32 PM
  3. rough idle... again...
    By pong in forum 5 Series BMW
    Last Post: 08-22-2007, 05:30 PM
  4. Rough Idle
    By hinchcliffe in forum 5 Series BMW
    Last Post: 08-27-2006, 10:12 PM
  5. Rough Idle
    By Incantation in forum 5 Series BMW
    Last Post: 06-25-2004, 12:59 AM
