Do you have any pics of the car to show how low it's sitting? I have some stock springs I just took off my car if you end up needing some.
In a previous post, I asked about spring/shock replacement. My 1989 535i is dragging its rear end as I go over bumps, into parking lots, etc. There does not have to be any bounce in the suspension. Even if I go through a dip very slowly, I can hear a scraping noise.
In this case, should I replace both rear springs AND shocks, or start with one? Which one first?
Norman
1988 M3 - Track rat
1989 325iC
1995 530iM
2000 323iT - UUC BBK, PSS9 Coilovers
2005 GMC HD Crew
I've attached the pics. The previous thread is here.Originally Posted by brodee
I'm looking to replace them with stock springs/shocks, so if you've got some lying around... I'd be interested.
Norman
looks like you may have a failed spring and/or bad shocks. Wouldnt kill the car to get new shocks and stock springs are good and plenty ringing in well under 50 bux anywhere.
