Results 1 to 3 of 3
Thread: EML disassembly
    Jul 2005
    Default EML disassembly
    I have almost completely disassembled the throttle body but I can t figure out how to unscrew and remove the commutator off. There is a torx bolt and it just unscrews but will not release. I have to remove so I can check out the major play which drives the butterfly flap.
    Thanks Joe
    Default EML disassembly?
    I assume you are talking about the throttling valve in design EML = without bowden cable.
    If so, maybe this helps
    http://www.e38.org/e32/throttles/BMWThrottles.htm
    http://www.bimmerboard.com/forums/posts/84595
    http://www.bimmerboard.com/forums/posts/83671
    Jul 2005
    Default Thanks Grand Master, just what I was looking for!
  1. 5HP30 (AS560Z) Valve Body disassembly
    Last Post: 08-03-2009, 07:40 PM
  2. E34 sport seats - disassembly help needed.
    By Jeff N. in forum 5 Series BMW
    Last Post: 01-22-2008, 10:41 AM
