Results 1 to 10 of 10
Thread: Martin, or NE1 else running t-stars on a 535 (m)
    Denver, CO
    Default Martin, or NE1 else running t-stars on a 535 (m)
    What tire pressure are you running on your setup? My tires are 235/45 on all four corners.
    patrick
    30 psi on the street.
    This is with Yokohama Db's. The es100 did seem to handle potholes better at 30 psi. Anything higher reminds me of the RD swaybars, bilstein sports & BavAuto springs.
    The roads suck here. The city is constantly tearing up the asphalt & leaving huge splits & grooves everywhere, bastartds. For some reason, bellevue doesn't use concrete, just crap asphalt.
    erased due to slander
    Denver, CO
    Default Thanks Martin.
    Quote Originally Posted by Martin in Bellevue
    Default 32-34 psi in Bridgestone RE750 (m)
    235/45/17
    roads suck in chicago too
    Bloomsbury, NJ
    I'm running Sumi HRT+ in a 235/45-R17 (well, right now I'm running studded Hakka Q's to be exact) at approx 35 psi, based upon the feedback I rec'd from this board. Had been running them at around 31/32 and found these tires' sidewalls a little too flimsy at that pressure.
    HTH,
    Tim G
    '91 535iM
    Wellington,New Zealand
    Default i run 35 psi all round too 235/45/17 and 255/40/17
    I assume then that the sale has gone through and you are the proud owner of a set of t stars(bastard)
    Gone but not forgotten
    i think mines are 37
    i have a 525 though
    Chicago
    35psi front w/ 245/45 17
    33psi rear w/ 255/40 17
    staggered T-stars with Pilot Sports on crappy Chicago roads
    Brandon J
    How do you like the RE750? I have the RE730 and loves it... I need another set soon
  1. :: Aston Martin DB7?
    By Qube in forum 5 Series BMW
    Last Post: 07-31-2007, 02:13 AM
  2. Martin / others with an oil cooler...
    Last Post: 06-03-2006, 07:12 PM
  3. Martin - you got the wrong car...
    By Jeff N. in forum 5 Series BMW
    Last Post: 07-19-2005, 09:54 AM
  4. OT aston martin
    By infinity5 in forum 5 Series BMW
    Last Post: 12-13-2004, 03:46 PM
