Results 1 to 8 of 8
Thread: Question about fuses
    NYC
    Default Question about fuses
    My #9 fuse (AC, Horn, Aux H20 pump) has been blowing. Initially I traced it down to a short by the aux fan switch and have taken care of that problem. And it worked. temporarily. I haven't been able to trace anything else down and im not sure where to look, but i changed the 15A fuse to a 30 and (knock on weeod) its been ok. Is this a dumb move?
    NC
    Default Never up the fuse size...fried wires follow...
    Quote Originally Posted by Jason
    I'd guess the following:
    A/C clutch coil going south
    aux water pump shot
    aux fan resistor
    Bill B.
    95 525i
    NYC
    Default Thanks Bill. I replaced the resistor already
    Can you help w/ location of tha aux water pump? I'm assuming its not the water pump at the front of the motor. Any idea what that or the clutch would cost?
    Thanks again.
    Long Beach, CA
    The auxillary water pump (At least on my car) is right under the heater valve. The heater valve is on the drivers side near the firewall.
    Default It wouldn't be the aux fan anyway, its not controlled by
    fuse 9 on the 90 535, 9 primarily sends power to the compressor control relay straight to the compressor clutch, and it sends power to the auxillary water pump relay through the relay and to the pump. And the horn ciruit as well...
    I would suspect the compressor clutch also. You can disconnect the relay for the auxillary water pump and determine if thats the problem, if after removing the relay it no longer blows then its probably the auxillary pump, but i would bet on the compressor clutch myself. The auxillary water pump relay is k50 in the front relay box.
    Thanks again.
    NYC
    Default Thanks Bill. Is it safe to drive w/ out that relay in? I
    only ask cause its about 100 degrees today and im sure to hit some traffic on the way home and there is nothing quite as unpleasant as sitting in a black on black car in slow moving traffic...
    NYC
    Default I guess thats a good place to start. Thanks
    Default Yep, it won't hurt to drive without the aux pump relay in, it only
    pumps water through the heater core... now you don't want to unplug the aux fan relay though.
  1. I was pulling fuses..
    By mzarifkar in forum 5 Series BMW
    Last Post: 04-27-2007, 08:19 AM
  2. Amp blowing fuses
    By Craig in Davis in forum 5 Series BMW
    Last Post: 09-05-2005, 08:13 PM
  3. Fuses
    By homer+vat in forum 5 Series BMW
    Last Post: 03-12-2005, 03:16 PM
  4. Fuses keep blowing!
    By grubby in forum 5 Series BMW
    Last Post: 09-01-2004, 11:29 AM
  5. Blowing fuses
    Last Post: 06-29-2004, 07:10 PM
