the installation wasn't done quite right or that the crankshaft pulley has a groove worn in it where the seal rides, any number of possibilities. Or that the engine has been overfilled with oil and the excess crankcase pressure has damaged the seal or that your crankcase ventilation is plugged up and pressure is building in the crankcase forcing oil out the seal, however if that was the case you would most likely see a rear main seal leak also.
Originally Posted by Anton CH.
