Has the car had the newer style metal water pump installed?Originally Posted by jaylebo
When was the last time the cars coolant was flushed?
-Charles
Hi all. I'm new here, and new to BMW-dom.
I've just inherited my father's 1990 535i, with an auto tranny and 220,000km on the clock (about 140,000mi).
I'll save the story for another time and cut right to the chase.
The aux fan never comes on. Never. The A/C also does not work. The car overheats any time the speed drops below 40mph, making the car undriveable.
Hoses, coolant and thermostat are new. Radiator is not OEM, but looks like a quality item in good shape. Probably replaced by a previous owner.
Now, my questions:
1. Could the aux fan problem be the reason why the A/C doesn't work, or is it wishful thinking that fixing the aux fan will restore the A/C?
2. Is the aux fan failure the cause of the overheating problem? The rest of the cooling system seems fine.
3. What are the steps for diagnosing the cause of the aux fan failure? I've read about aux fan switches and resistors, but can't figure out where they are or what they look like. I've ordered a Bentley manual but it hasn't arrived yet.
Any help is greatly appreciated. Thanks.
-Charles
Huh? Didn't know there was such a thing. How would I know?Originally Posted by dacoyote
Dunno exactly, although the thermostat was replaced last month. Would that have necessitated a coolant flush? The coolant looks a-ok.Originally Posted by dacoyote
I should add that this problem surfaced about six months ago, and it's been sufacing again and again despite my mechanic's efforts. Since the aux fan does not work at all, I'm likely to suspect it as the cause of the problem. But what do I know?
Thanks for the help.
First of all, the aux fan should come on when the temp gauge hit 3/4 or when the a/c goes on. Since the a/c doesn't work, does the gauge reach the 3/4 mark or higher when it overheats?Originally Posted by jaylebo
If you have the PO's repair records, you know when the water pump was replaced.Originally Posted by jaylebo
Does your car have a timing belt, which needs to be replaced at regular intervals 50,000-60,000 miles? If it has that belt and you don't have repair records I'd be worried about that. The good news is it's in the same area as the water pump and you can replace both at the same time.
Welcome!! Enjoy the new ride.Originally Posted by jaylebo
[QUOTE=jaylebo]
Now, my questions:
[/QUOTE}
Yes, it is very possible. Also check the fuse box, if the resistor is bad the fuse is probably blown.
Check the following link for more info:
http://www.nmia.com/~dgnrg/page_20.htm
Note likely. That sounds to me like the H2O pump may not be working properly. Only way to know for sure is to pull the pump. When is the last time your records indicate it was replaced? Most professionals are recommending replacement of the pump at 60K intervals now as a preventative measure.Originally Posted by jaylebo
See the link above for everything you would ever want to know.Originally Posted by jaylebo
Good Luck,
Rory
<Insert list of modifcations or clever saying here>
Hi,
Aux fan aside, it sounds to me like your fan clutch needs replacement. This is the viscous coupling that drives the primary fan. These do fail pretty regularly and with the mileage and age you have, it's a pretty good bet it's time.
Next step is to check the temperature sensors that control the aux fan. There should be two speeds, so check the wiring diagram. You can connect the fan directly to power to see if it comes on; this would confirm whether the fan itself is okay or not.
Regards,
Adnan
Thanks for all the replies. Here're the answeres to all the questions.
Oh yeah, it'll go into the red.Originally Posted by uscharalph
There is a belt, but I thought these cars had timing chains. There are no records, so I'd assume the worst. But I want to tackle the most likely culprits first, and since the aux fan isn't working it seems reasonable to start there. Doesn't it?Originally Posted by uscharalph
As far as I can tell, all underhood fuses are okay. Haven't looked under the rear seats.
Thanks for the tips, Rory. Water pump may not be that old. Unfortunately, my father wasn't the kind to keep records, but I have a vague recollection of him replacing that. His local mechanic is an honest and competent guy, but not a BMW specialist. That's why I'm inclinded to suspect that he totally overlooked the aux fan as a possible culprit, as it's damn near invisible to the uninitiated.
Adnan, thanks. I've read a bit about the clutch fan in my search that brought me to this site, and I don't see any evidence of it needing replacing. The fan blows strong at all engine speeds. Can you recommend some sort of test?
That's a little over my head. If you can describe exactly what to do, I'm sure I can do it, but I don't have a wiring diagram (yet -- Bentley is on the way), nor can I read one.Originally Posted by Adnan
Many thanks for all the help. Please keep it coming.
unless it's leaking or making a noise the pump is fine, m30s didn't have the plastic impeller, id bet whats happening is the bleeder line that goes from the left upper side of the radiator to the coolent tank is clogged somewhere, usually it's at the coolent tank end, when this line stops flowing the system can get airlocked
The M30 never came with a plastic water pump impeller, to my knowledge. All are metal.Originally Posted by jaylebo
Who installed the thermostat? My guess is that the rubber O ring wasn't inserted correctly, and the tstat is stuck. The car may cool down below the 1/4 tick mark under way if this is the case. The rubber O ring goes behind the tstat in the housing, fitting right up against the thermostat cover. Here's a pic of how it orients on the tstat itself:
...where the end in the photo is the cover side. Correct fitment is necessary: the tstat housing coolant passages are altered depending on what the tstat is doing.
best, whit
EDIT: also note that the gasket shown in the picture isn't the O ring....the O ring should be installed, not the gasket.
