Need to replace 4 rotors & pads?
Do you need to replace all 4 rotors & pads at once? I recently (500 miles ago) installed FRONT ATE rotors and Raybestos QS pads. Should I have done so on the rear? I do not think it makes any difference. Just want to be sure.
As expected, my braking is no better than before since my old Jurid pads were not quite worn down to wear sensors.
However, the pedal seems to take a bit more effort and travel than a year ago. This is one reason I changed Front rotors and pads. No change with the new pads. However, minimal dust!!!
FYI, my brake fluid has not been flushed in two years and I know it is due. Could this a factor?
TIA
