An E39 with a similar tire mix as yours are 29/33 for light loading and 33/41 for a full load.
I thought I saw a thread on this just a couple weeks ago, but I can't seem to find it.
What tire pressure should I be running - I've moved onto 18x8.5 with 235/40 in the front and 18x9.5 265/35 in the rear. Should I just keep it at the stock tire pressure?
How would I play around with the tire pressures to help induce some more oversteer (cause...I know ill have understeer with the staggared set up.)
www.KaRealtySF.com
Perfect. thank you thank you.Originally Posted by SRR2
I guess I'll go somewhere in the middle
www.KaRealtySF.com
