Results 1 to 4 of 4
Thread: clips of window switches available as single item?
    Default clips of window switches available as single item?
    I mean these little clips which hold the switch in the door panel. See where item # 4 points too.
    Replaced the bulb with an LED, but one clip disappeared inside the door when replacing the switch. Stll have another spare switch with clips, but do not want to waste this one.
    Or did someone make one by himself? Don't want to remove the panel for this.
    http://www.bmwtoolkit.com/BMW/61/0792.png
    Default here a better pic what I mean
    Probably have to disassemble an old PC or similar thing to find something which might fit as clip or can be made-to-fit.
    My dearest always complains that I keep all the old screws, nut, rings etc., but sometimes, one day you might need just that old piece.
    Before I scrap a damaged part I usually disassemble it just to see what happened and then I keep what I thing I might need in the future.
    Long Beach, CA
    How about a telescoping magnet to retrieve the clip. I keep one in my trunk tool compartment.
    Default have, have
    telescopic magnet, attachable LED flashlight, attachable mirror.
    If you have a V12 engine, that is the first thing you buy.
    Something like this
    And a stethoscope
    I have a spare window switch complete. But I look for the clip only, and I do not want to dive behind the door panel.
  1. Window Switches
    Last Post: 11-17-2007, 05:41 AM
  2. 92 E34 Rear window switches
    By crowegreg in forum 5 Series BMW
    Last Post: 08-11-2007, 12:10 PM
  3. Rear Window Switches
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 02-08-2006, 03:14 AM
  4. clips f. rear door window switches, where to get?
    Last Post: 09-23-2005, 07:47 AM
  5. Repaired window switches... pic
    Last Post: 11-08-2004, 07:09 AM
