I'm going to replace the upper and lower control arms this weekend. Can someone please post the torque specs for the following?
Lower Arm Bushing Bolt
Upper (thrust arm) bolt is 95.5 lb/ft correct?
bolts on the steering knuckle i've seen at 58 lb/ft is this also correct?
I'll torque them fully loaded.
TIA!
Patrick
I beleave that's 3 Jon K units of tightness. Seriously though, he just installed new bushings, so you might want to send him a pm with that
Q.
http://www.bimmer.info/forum/showthr...light=bushings
