Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Overfill? Easy way to remove some oil...
    Default Overfill? Easy way to remove some oil...
    Thought the board might find this useful, since there are posts from time to time on what to do if you put a little too much oil in the engine. I know this works on an M30 because I did it this weekend, it probably will work on all other engines too... someone will have to try it out and report back.
    Step 1: Remove the air box and AFM, but leave the spark plug wires hooked up. Just unclip the AFM harness and let it sit off to the side.
    Step 2: Remove the two nuts that hold the spark plug harness to the valve cover and ease the plug wires out of the way, still hooked up though.
    Step 3: Remove the valve cover nuts and pull the valve cover off and set it aside.
    Step 4: Start the engine. It may idle rough since it will be in open loop mode without the AFM signal.
    Step 5: Let the car run until the oil pumps up into the galleys, about 5-10 seconds depending on the weight of oil you use.
    Step 6: When you feel enough oil has been sprayed all over your entire garage, engine compartment, and recently-washed front fenders (hood liner too), shut off the engine.
    Step 7: Reassembly is the reverse of removal. Be sure not to over tighten the valve cover nuts. You can get away with reusing the VC gasket if it's fairly new.
    Maybe this will help someone out there as much as it helped me. And yes, I came up with this procedure all by myself. In fact, I was really just trying to track down an extra-noisy rocker arm, and just kind of "discovered" this cool trick. Had to share it with the board of course.
    - Robin
    Robin
    72 Chevy K10
    01 E39 M5
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by Robin-535im
    And yes, I came up with this procedure all by myself. Had to share it with the board of course.
    - Robin
    Of course!
    Robin that made me laugh out loud! Thanks!
    -ashley
    Paper Gaskets Suck!
    Lmao!
    SC
    Default Synthetic?
    Does this procedure work with synthetic oil?
    Quote Originally Posted by 525e34
    Yes sir it does.
    Robin
    72 Chevy K10
    01 E39 M5
    Long Beach, CA
    That's pretty hilarious!!
    Houston, TX
    Genius! You must copyright the technique immediately!
    Olympia, Wa
    That's all too much like work. stick a hose in your dipstick tube and use a vacum pump and suck it out.
    Did you really go through all that! What a mess it must have been.
    Ted K
    90 535 5-speed
    Quote Originally Posted by Ted K
    I was thinking I could drop the tranny to get to the rear main seal, then pop the seal and let it drain from there, but I didn't have anywhere to put the tranny to keep it out of the way.
    Robin
    72 Chevy K10
    01 E39 M5
    Apr 2004
    Good technique! However, for the next overfill, you can save on the wrenching: simply remove the oil fill cap and do a few loops at the local skate board track. A 360 is worth about 125 mls ....
  1. Is this an easy fix?
    By dec1184 in forum 5 Series BMW
    Last Post: 04-01-2008, 08:23 AM
  2. Pretty easy one
    By ThoreauHD in forum 5 Series BMW
    Last Post: 02-19-2007, 11:01 AM
  3. Replies: 11
    Last Post: 01-13-2007, 09:15 AM
  4. Ain't That Easy!
    By jiminEcricket in forum 5 Series BMW
    Last Post: 12-03-2004, 11:25 PM
  5. Overfill!
    By Mike in forum 5 Series BMW
    Last Post: 02-12-2004, 03:23 PM
