Results 1 to 5 of 5
Thread: Need lock nuts for Thrust Arms....
    Missouri, USA
    Default Need lock nuts for Thrust Arms....
    Here's the scoop.
    I had NO idea the BMW lock nuts for the Thrust Arm Bushing bolt were impossible to buy. None in town and I need some for the weekend repair.
    Sooo....
    I found M14x1.5 NYLOCK Grade 8 nuts (HEAVY DUTY), locally. Turns out the 1.5 pitch is a real oddball.
    Will these suffice?
    Since the nuts are NOT in a high heat location they SHOULD be fine.
    With 94 lbs. of torque on them, it should take the force of the earth's rotation to break them loose anyway.
    Thanks in advance for any input,
    Bill
    they should be just fine.
    Shhhhh (I used the old ones)
    Missouri, USA
    Default I won't tell a soul....
    Like I said before....with THAT much torque on them, it'd take a horrendous force to snap them/break them loose anyway.
    Thanks for the vote of confidence.
    if in doubt use a little loctite
    Missouri, USA
    Default I can't wait to get the new ones on!
    I ordered the new Thrust Arms with the 750i bushings from BMA.
    Unreal price. They're SUPPOSED to be here on Friday (tomorrow).
    Long weekend for me so it's Beemer repair time!
    My 525 has the signature "ga-gunk" sound when the right front tire impacts anything and both ball-joint boots are gone on the Thrust Arms.
    That ought to tighten up that front end a bit.
    Besides, the toe is WAY out on the car...due to the ball joint slop allowing the wheels to "steer" toward the rear?
    We'll see!
  1. About to do thrust arms, control arms, and shocks
    By 530iBall in forum 5 Series BMW
    Last Post: 09-24-2007, 12:20 AM
  2. thrust arms or upper control arms
    By gsxr9 in forum 5 Series BMW
    Last Post: 01-25-2007, 11:02 PM
  3. Replacing thrust arms vs. thrust arm bushings
    By JAlfredPrufrock in forum 5 Series BMW
    Last Post: 05-09-2005, 08:08 AM
  4. Replies: 2
    Last Post: 10-29-2004, 09:16 PM
