Results 1 to 10 of 10
Thread: ::.. Brake Questions
    T慈愛慈意愁慈
    Default ::.. Brake Questions
    1. When reversing/rolling backwards, the brakes 'catch' sometimes... the pedal depresses by itself a bit and releases. Feels like it notched something and passed over. This only happens going backwards and not very often. Just had the brakes done, shoes/discs and all. What might have been missed?
    2. Depressing the brake pedal interferes with AM radio reception. Grounding, or something else perhaps tied with the first question?
    Default Assuming I understand your description...
    anything other than brake judder when braking in reverse is probably due to the ABS readjusting itself to function in this direction, or something to this effect. This is what I've been told. I believe this is also normal. You should've had this happening to you even before you did the brake job. This has been happening to me for years and it doesn't happen all the time. It seems it's reverse speed- and level of braking effort-dependent. Others may want to comment on this.
    T慈愛慈意愁慈
    Yes, it did happen before the job... I was hoping the job would take care of it... My parking brake was hosed so I thought that was it.
    Houston, TX
    Radio reception interference is usually the result of electrical noise - in your case, it sounds like you have a brake switch that's dying on you. In my case, I got a "Brake Light Circuit" warning on the dash read-out and intermittent brake lights. The switch is a pain to get to, but easy to replace. If that's not it, then maybe there is a loose connection or frayed wire in your brake light circuit. Hope this helps.
    Aug 2005
    Toronto
    AM radio? What's that?
    Houston, TX
    Is much very ancient way to hear news and sports in car from speakers - also, too, rght wing talk radio propaganda. USA! Support your President.
    Vancouver, Canada
    lolol
    -inc
    '91 e31 850
    '90 e34 535
    '02 CBR F4i stunt/track bike
    '07 gsxr 750 stunt bike
    Long Beach, CA
    Quote Originally Posted by jaylebo
    That was my reaction also!
    T慈愛慈意愁慈
    AM... 680 news. Can't live without the traffic reports down here Every 10 minutes.
    clean ride bro!
  1. Brake project questions!
    By healtoeit in forum 5 Series BMW
    Last Post: 04-12-2008, 04:27 AM
  2. Brake fluid loss - questions
    By Adnan in forum 5 Series BMW
    Last Post: 12-09-2007, 11:59 PM
  3. Brake squeal and bedding-in questions.
    By Dan in NZ in forum 5 Series BMW
    Last Post: 01-17-2005, 05:06 AM
  4. Brake upgrade questions
    By spddmn713 in forum 5 Series BMW
    Last Post: 01-15-2005, 10:36 PM
  5. Intro & big brake questions
    By Jake in forum 5 Series BMW
    Last Post: 04-22-2004, 05:22 PM
