say what?
I definetly want and NEED to see pictures to figure out what your saying.
Originally Posted by
SRR2
It's a pentagonal socket. I made my own tool out of a nail slightly larger than the socket. It was a common flat-head nail. I ground the head into a regular pentagon, just by eye. Sounds harder than it was, actually it took less than two minutes. Then I set a fence on the grinder and used the facets on the head to set the angles at the tip of the nail. Just grind a bit off the tip, one facet at a time. A couple of tries as you decrease the size of the tip and you'll have it. The whole project took under than 10 minutes. And when you're finished, you'll have something sort of cool to talk about with other car people.
