Results 1 to 2 of 2
Thread: clutch problem
    Aug 2004
    Dubai
    Default clutch problem
    I just have a small problem with my clutch ... it doesn't release the clutch after some time driving ... as if it lost oil pressure off the slave cylinder. any advice?
    Aug 2004
    Default System Compliance
    Hi,
    Compliance in the system can come from three places - leaky master cylinder, leaky slave cylinder or a leak in the system. A flex hose that expands like a balloon can also cause high compliance.
    I would begin by checking for brake fluid leaks. For good measure, bleed the system and change the fluid as there may be air/debris in the system. If there are no leaks, the cylinders are suspect. Probably best to replace both.
    Regards,
    Adnan
  1. Anyone had any problem bleeding the clutch?
    Last Post: 12-08-2009, 03:09 AM
  2. Sqeaky clutch. Is this a problem?
    By bbig119 in forum 5 Series BMW
    Last Post: 04-23-2007, 12:15 PM
  3. m50, 5speed clutch problem
    By paul p (chi-town) in forum 5 Series BMW
    Last Post: 03-07-2005, 01:22 PM
  4. is this a clutch problem?
    By Matt M. in forum 3 Series BMW
    Last Post: 08-29-2004, 04:13 PM
  5. Transmission/New Clutch problem. Help!
    Last Post: 05-06-2004, 10:51 PM
