Results 1 to 7 of 7
Thread: OT : ? Nikasil problem in E39 sixes in Oz
    Aug 2004
    Regional NSW, Australia
    Default OT : ? Nikasil problem in E39 sixes in Oz
    Am currently looking at a '98 523i to add to the stable - no the E34 isn't going. For you in th US, the 523i is a de-tuned (170 hp) version of the 2.5 litre M52 in the E39.
    Imagine my surprise when my mechanic told me that there was a problem in the '96-00 523i and 528i cars as they have Nikasil blocks, but that from 2000 - on all the 525i and 530i cars use Alusil blocks.
    ( At least, thanks to this forum, guys and girls, I didn't look a complete idiot and asked an intelligent question about a leakdown test ).
    Am now organising this test on the car.
    What I don't understand, however, is if the Nikasil problem was related to high fuel sulphur levels, which we apparently don't have and haven't had in Oz, why has my mechanic seen lots of failed Nikasil engines in both 5 and 3 series cars ?
    Any ideas or input appreciated .
    "I'm not the village idiot.
    according to my knowledge it was the biggest problem in USA and the U.K.
    Never here in Japan.
    Here some info
    http://www.bmwland.co.uk/talker/view...php?t=373&vm=r
    http://www.bmwworld.com/engines/nikasil.htm
    And quite often apparently the mechanics put the fault on this issue if they do not know the real problem.
    Aug 2004
    Thanks Shogun, as usual - excellent info !
    Interestinger and interestinger - and here I always thought it only affected V8s - which it obviously did in the US as they apparently didn't import the M52 engine.
    Must speak to my mechanic again tomorrow to clarify the issues he has seen .
    Thanks again !
    Aug 2004
    Spoke with my mechanic again. He used to work for BMW and told me of many Nikasil engines that had been replaced here in Oz.
    He explained the issue this way :
    Honing marks in the cylinder wall are meant to retain oil which lubricates the piston.
    In Nikasil lined blocks the honing marks are removed by the piston rings and the cylinder walls become too smooth and cannot retain the oil required for lubrication so the piston is running virtually dry.
    This then leads to excessive wear of the rings and loss of compression which replacement of rings will not fix for very long as the new rings also wear out very quickly.
    I am having difficulty understanding if this is the classic Nikasil problem or if my mechanic is describing something else.
    Any comments welcomed.
    Aug 2004
    Bump !
    Anyone ?
    Wellington,New Zealand
    Apparently in NZ there was never a nikasil issue...according to BMW,i will ask my indy about the M52...
    Gone but not forgotten
    Have the leakdown performed or just move on to another car. Does the car run/idle good now?
  1. School Me On The Nikasil Problem
    By wishihad50k in forum 5 Series BMW
    Last Post: 12-05-2006, 03:38 PM
  2. Nikasil???
    By Incantation in forum 5 Series BMW
    Last Post: 03-23-2005, 10:30 PM
  3. 1995 530i Nikasil Problem
    By f1restarter in forum 5 Series BMW
    Last Post: 12-16-2004, 06:21 PM
  4. Nikasil problem on 328 and 528 M52???
    By Bruno in forum 5 Series BMW
    Last Post: 09-18-2004, 12:18 AM
  5. Nikasil
    By spitfire in forum 5 Series BMW
    Last Post: 06-20-2004, 10:55 AM
