Results 1 to 4 of 4
Thread: Upper Control Arm w/ M5 bush...
    Nov 2004
    Santa Barbara, CA
    Default Upper Control Arm w/ M5 bush...
    To anyone that has used the upper control arms with M5 bushings:
    Did you find the control arm assembly with the M5 bushings already pressed in, or did you press them in yourself? The ETK shows the bushings as a seperate part number (not available installed).
    Is it worth the extra $$ and effort over the 750 bushings?
    Thanks.
    Nov 2004
    Santa Barbara, CA
    Default found some prices...
    I made some calls and found some prices:
    BMA
    Thrust Arms w/750 bushings installed - $99 ea (lem)
    Thrust Arms w/M5 bushings installed - $130 ea (lem)
    STEVE HAYGOOD (prices include shipping)
    Thrust Arms w/750 bushings installed - $71 ea (TRW)
    Thrust Arms w/M5 bushings UNinstalled - $110 ea (lem)
    If you have a press, sounds like Steve can give you a good deal on the M5 bushing set.
    Honolulu
    Default If you wanna go cheap
    I have seen whole front end sets with either the 750 or the M bushings floating around on Ebay.
    But they may be Hamburg Tech stuff
    Long Beach, CA
    Default eBay Trust Arms
    Yeah, I just checked and the Hamburg Techs w/ 750il bushings Hamburg Tech were going for 99.99 a pair and they had Meyle with 750i V12 bushings Meyle starting at $129 a pair
  1. Upper Control Arm Bushing
    By Luftpost in forum 5 Series BMW
    Last Post: 09-18-2009, 05:45 AM
  2. M5 Upper Control Arm Bushies in 540?
    By Jehu in forum 5 Series BMW
    Last Post: 07-15-2007, 06:45 PM
  3. upper thrust arm & bush replacement
    Last Post: 12-24-2006, 04:56 AM
  4. How-To for upper control arms?
    By sirius_GTO in forum 5 Series BMW
    Last Post: 10-16-2006, 01:55 PM
  5. Upper Control Arm/Thrust Arm
    By athflying79 in forum 5 Series BMW
    Last Post: 02-13-2006, 12:39 PM
