with about 8K miles on them and have been pretty happy--good dry grip, decent wet traction, relatively low noise (noise is not much of an issue for me,) nice tread patternand. Also, here are other yakchips about this tire I posted...
http://www.bimmer.info/forum/showthr...+ZIEX+512+tire
Recently, Falken introduced the new ZE-329 in the states. Here are some quotes from a tire expert or someone who is probably connected to Falken tire marketing. I've noticed this tire has a similar tread pattern than Sumitomo's HTR+. Go figure, Falken is owned by Sumitomo anyhow...
***That being said, the ZE-329 has turned up better stats over the ZE-512. The ZE-512 began its legacy as a "long-lasting" "high performance" all season tyre. In actuality, it is quite a nice tyre but it should not be marketed as long-lasting - it is not.
The ZE-329 has a superior silica-based tread compound that allows for longer life without sacrificing traction in weather and extends the "sweetness" of the rubber as the tyre ages maintaining traction levels.
The ZE-329 also has other subtle difference such as Falken's pattented rotation-divots (holes in the tread - can be seen in the picture above) which allow you to see when the tyre should be rotated as well as be able to see how the inside/outside wear is comparing.
The ZE-329 is also a non-directional tyre which makes it a more practical tyre. The ZE-512 can not be cross-rotated so you can not even out the wear by switching sides as you rotate.
If given the choice, the ZE-329 is the superior of the two tyres. It's too bad you will likely NOT be able to get them at MOST Falken dealers in North America.***
Originally Posted by jaylebo
