Results 1 to 7 of 7
Thread: What steering components commonly fail?
    Aug 2005
    Toronto
    Default What steering components commonly fail?
    My car's steering is a little vague, especially around the straight-ahead. It's not terrible, but I don't have anything to compare it to.
    Are there any common problems that can lead to this?
    Do these cars have a rack and pinion or a recirculating ball system?
    Nov 2004
    E34 uses the recirculating ball system.
    The replaceable steering linkage parts are:
    1. left/right tie rods (#3)
    2. center tie rod (#9)
    3. idler arm (#14)
    4. Ptiman arm (#10) this arm has no bushing so really isn't normal to replace since the bushing is on the ctr tie rod and the other end is attached to the steering pump.
    Q
    95 525iT / 97 740iL
    Did you tighten the steering shaft nut under the dash yet?
    Honolulu
    Default Could this be that loose nut
    Behind the wheel again?
    It's a chronic problem with many cars
    Aug 2005
    Toronto
    Dunno what you're talking about.
    If it's a recirculating ball system, then maybe this is normal.
    Honolulu
    Default this may help
  1. Replies: 20
    Last Post: 09-17-2008, 07:10 AM
  2. SRS - what are its components?
    By BadAss95-530i in forum 5 Series BMW
    Last Post: 03-11-2008, 08:36 AM
  3. Replies: 6
    Last Post: 11-23-2007, 10:42 AM
  4. please HELP: what tensioner components do i need to get..
    Last Post: 03-15-2007, 12:17 PM
  5. Shock/Spring components
    Last Post: 02-07-2005, 03:36 AM
