Results 1 to 10 of 10
Thread: E34 Cruise
    Perth Western Australia
    Default E34 Cruise
    cruise control 530i v8 '95 not working
    any ideas?? jack perth western australia
    Linden, NJ
    Default Safety Recall
    In the United States the cruise control had a safety recall. Check with your nearest BMW service center. Not sure if it applies on your continent, but its worth a try. Look here for more info.
    1995 530im
    151k nikasil miles
    guyer Guest
    Default Same problem
    I've got a '94 and the cruise doesn't work. I've read about the safety recall in other forums but I don't think my problem is related. The cruise simply doesn't work at all. I've checked the fuse but of course it couldn't be that easy. I've also asked my mechanic (friend) and he said he hasn't seen any e34 with cruise problems. I really need cruise! I'm on the road all the time!
    baton rouge, loserana
    out of all of those tsb's i didn't see anything about loose oil pump bolts on the v8's, i've seen em completely fall out, red locktight em in
    Quote Originally Posted by Mike
    Niagara on the Lake, Ontario, Canada
    Default cruise
    manual or auto...
    if manual, lift up on your clutch with your toe underneath....then try the cruise... do the same with the brake...worth a try
    Gordon Lawson
    Niagara on the Lake
    Ont., Canada
    1989 535i 5speed "Eat'n"
    guyer Guest
    Default Nope -- Automatic
    Do you think there is a computer module that is for cruise only? 'Cause cruise is the only thing that doesn't work.
    Coastal North Carolina
    Default The Cruise unit has a rheostat on the board...
    The rheostat tells the cruise control unit where the throttle is. On my 95 525iA, this rheostat would get dirty and carbonized and the cruise would stop working. On two occasions I removed the cruise control servo from the inner fender well, disconnected the throttle cable from the throttle body and put the unit on my bench. If you remove the cover from the cruise unit, (6-8 flat head screws), you can see how the mechanism works. It is a little tricky getting it apart and back together because the cable is attached to a short rubber belt that wraps around a spring-loaded spool (this is what pulls the cable) and you have to get that spring rewound and to put it all together.
    Once you get the cover off, you will see the contact points that need cleaning. Some Stabilant would probably be a good idea on the contact strips.
    It isn't too bad, just take your time. I wish I had taken pictures when I had the chance...
    HTH,
    Scott
    Wilmington, NC
    01 525iA For Sale
    Coming Soon: 2005 X3 3.0i
    05 Jeep GCL HEMI
    85 318iA SOLD
    96 Jeep GCL SOLD
    guyer Guest
    Thanks for the in-depth reply. To your recollection, is this cc servo under the brake booster right behind the driver's side high beam? Looks pretty difficult to remove.
    Also, should the throttle cable that connects to it follow the primary throttle movement all the time or only when the cc is engaged? It doesn't so I think that may be part of the problem.
    Aussie Jack -- Have you had any luck?
    Quote Originally Posted by guyer
    On the 525iA it was really easy to remove, driver's side, in front of the shock tower. I am not sure about the 540.
    I don't think the cable moves until the CC is engaged. If I recall correctly, there is a long metal rod at the end of the cc cable that slides along the throttle linkage when CC is not engaged.
    Scott
    Wilmington, NC
    01 525iA For Sale
    05 Jeep GCL HEMI
    85 318iA SOLD
    96 Jeep GCL SOLD
    A faulty brake switch will cause cruise to fail as well.
    http://www.bmwe34.net/e34main/Mainte...ake_switch.htm
  1. Where is cruise control mod on my 94 530?
    By myles in forum 5 Series BMW
    Last Post: 04-03-2008, 01:31 AM
  2. cruise lag fix
    By stx133 in forum 5 Series BMW
    Last Post: 10-02-2007, 08:45 AM
  3. cruise control?
    By mercury187 in forum 5 Series BMW
    Last Post: 05-05-2005, 12:14 AM
  4. Anyone with cruise control willing to help?
    By Interceptor in forum 5 Series BMW
    Last Post: 02-04-2005, 09:46 AM
  5. cruise control
    By postjay in forum 5 Series BMW
    Last Post: 11-17-2004, 11:01 AM
