Head of a 2 to 5 lb sledge, without the handle in it you have a hole in the middle that you can get a piece of mild steel bar stock and weld a
grade 8 bolt on the end that will screw into the end of the rocker shaft, then on the other end you weld a plate... when you slide the hammer head over the bar stock and then screw the bar stock into the end of the rocker shaft, (the threaded hole) then you slide the hammer head out to the plate you welded on the endof the shaft as a stop and you hammer the rocker shaft out this way.... I have one laying around that I made for mercedes v8 timing chain stuff, i'll try to dig it out and photograph it if my explanation isn't clear enough..
Originally Posted by Hector
