Results 1 to 9 of 9
Thread: which one should i use?
    Central NJ - USA
    Default which one should i use?
    heheheh
    i was just looking over http://www.kilander-racing.se/ and i saw they made 500hp on the M30...
    and pat p down in FL made something like 600...
    that is just nuts!
    Jun 2005
    OK for the clueless....What are those?
    Bay Area, CA
    Those are snails.
    www.KaRealtySF.com
    Jun 2005
    Is that a joke or a serious answer like the dog bones which I still don't understand what they do.
    Central NJ - USA
    those are turbos =]
    shaped like a snail
    turbos force air into the engine..more than it could suck in by itself
    Long Beach, CA
    Quote Originally Posted by bahnstormer
    heheheh
    that is just nuts!
    Bigger is allways better, right?
    Quote Originally Posted by Gayle
    Those are some of the fastest snails on the planet Gayle. 'Turbos' take exhaust pressure to 'spool' additional air into the combustion chamber. Add increased fuel pressure and voila.........Snails!! I don'yt know $hit about snails compared to most of these guys, so if you want more info ask someone else.
    Regording 'dog bones'
    Dog bones are an integral and often worn/broken member of the rear suspension family. The 'swing support', as they are otherwise known as, connect the end portions of the rear sway bar to the sub-frame (?). And, Oskar (below) agrees that they do indeed look like little dog bones.
    Good questions,
    Dave M
    Bay Area, CA
    I thought dog bones were referance to the rear pitman arms?
    www.KaRealtySF.com
    Quote Originally Posted by uscharalph
    Thats what she said.
