Hey All,
This past winter I discovered that my T-stat was stuck (or broken) in an always open position. But figured that summer was coming and it wouldn't hurt to have the stat wide-open when the air temps hit the mid-nineties, so I left it in (I know...stupid).
Throughout the summer the temp needle has stayed at the 12 o'clock postion with no variance. But recently the needle is pegged one needle's width to the right of center (it must be getting more conservative
). Once the engine warms up the needle NEVER goes to 12 o'clock or below and now when coming off the highway it goes more towards the 3/4 mark. I also noticed this behavior on Monday in some stop and go traffic.
My hoses look pretty new, I have the t-stat and o-rings and coolant to do the change.
Questions:
Could the T-stat have not been seated correctly and now it is?
Is their anything else I should look at?
What are the symptoms of a failing fan cluctch and how do I check it?
Do I need to purchase and replace the T-stat housing gasket as well? (i have the al housing)
If my fan clutch is failing, what are the advantages/disadvantages to changing to an electric fan and how difficult is the change (i.e. is it worth it?)
Thanks!
-ashley
