Results 1 to 9 of 9
Thread: Brake noise
    Default Brake noise
    I just replaced pads and rotors on my 1989 535i. However, now when I brake (particularlyon a steep hill) I hear a sort of muted rapping sound. There is no shake or feel of any kind through the pedal or steering wheel. I redid one side just to make sure there was nothing obviously out of whack but found nothing. Does anyone know what the problem might be? Thanks and regards,
    Aug 2004
    Milwaukee, WI; Chicago, IL
    Are you sure that the rotor mounting bolts are firmly in and that the rotors are balanced?
    1990 BMW 535i 5 speed - Black on Grey, LSD
    "rapping sound"
    Please elaborate.
    Was an anti-rattle clip left off of one side?
    Something probably wasn't set correctly -- pads, carrier bracket bolts, misadjusted park brake (if the rears were replaced) can all make noise.
    Brakes are EASY. So easy they can be dangerously messed up. Anyway....
    best, whit
    Default brake noise
    Quote Originally Posted by lowell
    best, whit
    Thanks for your thoughts. I checked all those items. Don't know how the carrier bracket bolts could be mis-set and, as to the pads, there is so little play in the carrier it seems the pads can only be inserted properly. There aren't shims associated with these pads, are there? Regards,
    I have no way to check the rotor balance. They are new Brembo's. I did not over tighten the rotor set screws, because it seems the wheel lug bolts hold the rotor firmly in place. Thanks and regards,
    I thought hard about the word "rapping" but couldn't come-up with a better alternative. Perhaps thumping is an alternative. It's not a clank or ding, certainly not metalic and the noise is syncronized with the speed of the vehicle, although it seems more noticeable at low speeds. Thanks and regards,
    Tampa Bay, Florida, USA
    Did you mark the tires and replace them exactly as they were mounted previously?
    Check your tires for balance, flat spots etc.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Long Beach, CA
    Quote Originally Posted by MBXB
    ???? I've never heard of that?
  1. Rubbing Noise Caused by Parking Brake/Spring Kit?
    By Dathaeus in forum 3 Series BMW
    Last Post: 02-25-2009, 02:36 PM
  2. front brake thumping noise
    Last Post: 06-16-2008, 08:59 PM
  3. squeaky noise at brake pedal- lubriacte the brake booster?
    By werminghausen in forum 5 Series BMW
    Last Post: 06-12-2008, 01:22 PM
  4. new wheels, noise from e-brake handle?
    By 93-525i in forum 5 Series BMW
    Last Post: 08-24-2005, 03:39 PM
  5. noise when releasing brake??
    By mikedev10 in forum 5 Series BMW
    Last Post: 04-13-2005, 10:57 AM
