Here on an old roadfly post
Originally Posted by crowegreg
The previous owner of my 92 525i removed the factory cell phone. On a previous thread, I read when the phone is removed it would cause the date/time/etc from being displayed on the dashboard. Has anyone experienced this same situation? If so, where on the car should I start looking to fix this problem? The previous thread mentioned some flat clips, and running wire between some of the connections, but he had the luxury of knowing where these clips were since he removed the phone.
Thanks for your assistance!!
When you push in the turn siganal stalk, do you get OBC info on the led readout in your instrument cluster?Originally Posted by crowegreg
No, that's what I'm looking to fix. Everything that I've read talks about when the phone is removed, you need to do some special wiring. But with the phone installed before I purchased the automobile, I do not know where these wires might be located. All the links talk about what needs to be done, but they fail to tell "where" the fix needs to be done.Originally Posted by uscharalph
Originally Posted by Bill R.
Thanks for the link. I've read it previously, but I can't determine where these items are in order to fix them. Any assistance would be appreciated!!
