That would work.....
You could also run a search....
First Link Free
-Charles
With the 12 volt fuel pump removed from the car, what's the best way to test it?
Hotwired to 12V battery?
How to adjust to correct amperage?
Pls. advise, and forbear my electrical ignorance.
First Link Free
-Charles
I miss my e34
once one pump that worked intermittently when energized outside the tank. You should try to cycle it on-off several times. No long runs as pump is refrigerated by fuel flow. Also, to have it running not necessarily means it is pumping right.
Best way to check it, is installed and tested by Bentleys suggestions.
Javier
