Results 1 to 4 of 4
Thread: Vibration
    Mar 2004
    Sussex, UK
    Default Vibration
    1992 525i SE (auto), 215k miles. I replaced my prop-shaft (driveshaft) donut coupling when I bought this car 3 years ago. Recently, my friendly local mechanic (GM franchise) replaced the shaft's centre bearing as the housing had fractured. After he did the work, there is a quite harsh vibration - from about the centre of the car - under load from a standstill, like when you give it some throttle. I thought he must have failed to tighten the centre bearing housing bolts, so I gave it back to him. He has checked all the fastenings that could be involved and everything is tight. Any ideas?
    Rod
    needs to be inspected, might need a new driveshaft.
    Mar 2004
    Sussex, UK
    Problem is, nothing looks wrong with it - there's a minute amount of play in the rear (to diff) joint. I thought it might not have been put back in the same position as it was taken off, making it out of balance, but would expect that to make it vibrate more. It only vibrates under high load in 1st and then only for a short time. You drive thro' it and it seems OK, certainly up to 80 - 85.
    Rod
    Near San Francisco, CA, USA
    Default Besides play, you need to check for binding...
    Sort of a "notchy" effect around the center. This, too, can cause vibration. Also, check for proper preload of the CB (See Bentley.).
    Quote Originally Posted by Sadgrandad
    Rod
  1. Got a vibration between 35-45 MPH what can it be?
    Last Post: 04-12-2010, 01:58 PM
  2. vibration
    By bmw new guy in forum 5 Series BMW
    Last Post: 12-24-2006, 05:57 PM
  3. Vibration around 50-60 mph.
    By HDhandyman in forum 5 Series BMW
    Last Post: 11-04-2005, 12:59 PM
  4. Vibration at 78 - 81 mph
    By sbraun14 in forum 5 Series BMW
    Last Post: 03-26-2005, 04:32 AM
  5. Vibration at 65 mph. What the...?
    Last Post: 06-22-2004, 11:38 AM
