ABS issues on E39's are a frequent topic on Roadfly. Hope you don't have a '99, they're suppose to be the worst. I think they eliminated the dif sensor for the speedo in the E39 and use ABS/DSC wheel sensor(s) for the vehicle speed. Does your speedo still work?
Paul Shovestul
Originally Posted by
tim
I guess I forgot to mention it's an m62
and I should refine my question. The issue of whether it is front or back wheel sensor is pretty trivial. Presumably it's front.
I guess what I'm after is whether or not it could be that speed sensor on the DSC compressor that I saw in the ETK. That looks like a pain and it looks like you have to undo those pipes in the back just to be able to get at it.
When you get a speed sensor code on a generic reader like I did, would it specify between "vehicle speed sensor" and "wheel speed sensor"?
'sup?
