could be thrust arm bushings, center bearing, guibo(if you have one), lot of other things. do a search. also i think i remember billr or someone asking if you feel it in the floor or through your seat as a way to identify the prob.
Hey guys,
I'm having strange problems. My car is vibrating (steering and feet) between 50-60 mph then everything is fine again. Anybody know what this could be?
Stephen
-Pekka
Check the archives. Typical problem on our cars. If you are in Lexington, Ky as I think you are. Motorsports can fix you up. Call Curt Richards-owner at 859-259-2801. They are reasonable, honest and a bit cheaper than the dealer.
I need to do the same. Good luck!
Yep, Archives are once again, treasure trove. I tried every thing from vibration to shudder. who knew it was called the 50-60 shimmy. I think there's more than enough info here to help me solve the problem. Thanks gang!
I just came to have the same problem after doing a tire rotation. Changed them back and bang, problem gone. Cupping issue in the tires in my bet. Also, check the balance in the tires and for a bent rim.
Stephen
535 Rear Wheel Enjoyment
do a search
someone asks about this every week
-inc
'91 e31 850
'90 e34 535
'02 CBR F4i stunt/track bike
'07 gsxr 750 stunt bike
Yup, thrust arms, control arms, sway links, hubcentric rings and last but not least...tires that go out of round after a while (Dunlop 'eggs' especially).
Cheers,
Duey
1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
Just wondering if you guys change rims eitheir upgrade with new BMW OEM wheels or aftermartket wheels. If you did you will need a Hubcentric converter kit.
If you are still using your stock wheels check the condition of your front Hubs.
hmm...interesting angle, I'll check into that on my car.
Originally Posted by kidlat
Lol
I miss my e34
