Results 1 to 10 of 11
Thread: whine in steering column
    Nov 2005
    denver
    Default whine in steering column
    my 95 540 has developed a whine in the steering column when it is initially started, and/or when the ignition is in the position just prior to starting the engine.
    this whine continues when engine starts and eventually stops, or I can turn the ignition off, and turn it back on and sometimes it will stop, particularly after 2 or 3 minutes.
    cold temperatures seem to be prolong the whine.
    is this a symptom of something about to fail?
    Jun 2005
    Cleveland, OH
    Quote Originally Posted by sgeorge
    Maybe it wants some cheese for the w(h)ine....
    HAHAHAHAHHAHA
    darn I am funny....
    Do you have an ajustable steering wheel with memory seats?
    -Charles
    I miss my e34
    when you turn the wheel?
    Tampa Bay, Florida, USA
    Check your PS steering fluid level?
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Nov 2005
    denver
    YES.
    Quote Originally Posted by dacoyote
    HAHAHAHAHHAHA
    darn I am funny....
    -Charles
    Nov 2005
    denver
    no. when simply sitting still or running down the road. when I brake...it does mute the whine but then returns when you let off the brake.
    most mornings I simply run a few blocks, turn the car off, and as I turn the key to the number 2 position, I will know whether it is done whining or not.
    you need to give us better clues...describe the whine, does it sound like its coming from under the dash or outside the car?
    Nov 2005
    denver
    it sounds like it is coming from the steering column under the dash. sounds like a pump that is dragging.
    not too dissimilar to the whine caused by the power steering pump when low on fluid.
    seems to come from the same area as the clunk clunk clunk of the heating system valves that operate when you shut the car down. Perhaps it is associated with that system.
    Nov 2005
    denver
    the whine is not associated at all with turning the steering wheel.
    i've got the slow power steering system leak and am familiar with those sounds.
    I'm assuming you have a power telescoping column.
    It's not entirely uncommon for them to eat gears. More of an E38 issue.
    My money is on the potentiometer thinking the column is out of place, then trying to move it.
    Just a thought.
    best, whit
  1. Anybody Know how to reassemble a steering column?
    By Five2FiveTD in forum 5 Series BMW
    Last Post: 01-28-2008, 04:18 PM
  2. Steering column dis-assembly
    By Zeuk in Oz in forum 5 Series BMW
    Last Post: 03-02-2006, 05:38 PM
  3. Steering column nut strangeness
    By howardc64 in forum 5 Series BMW
    Last Post: 07-29-2005, 06:08 PM
  4. HELP PSE Steering column lock!
    By ggrigg in forum 5 Series BMW
    Last Post: 03-14-2004, 03:50 AM
