Results 1 to 2 of 2
Thread: Which differential oil?
    Sep 2004
    Iowa
    Default Which differential oil?
    I have a 2002 530. I believe that BMW uses/recommends Castrol SAF-XO or SAF-XJ (if limited slip differential), which seem to be available only from delaler service departments.
    Does this car have a limited slip diff? I think not, but am unsure.
    Is it encessary to use the dealer supplied gear oil or could I just use Mobil1 75w90? It has nearly identical specs (density, viscosity index, etc) according to manufacturer web sites.
    if the M1 is the same weights than it should be safe to use, non synthetic is a no-no.
  1. Is it my Differential?
    By Jehu in forum 5 Series BMW
    Last Post: 09-30-2007, 06:44 PM
  2. Differential ID & Oil
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 03-15-2006, 09:19 PM
  3. differential fluid
    By ejhiggins in forum 5 Series BMW
    Last Post: 01-15-2005, 05:34 PM
  4. Need differential for 535is
    By jwhyland in forum 5 Series BMW
    Last Post: 01-12-2005, 10:04 PM
  5. e34 differential
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 11-07-2004, 12:18 AM
