Hi folks
I did the check where you press the check control button while turning ignition to on earlier ... the one where it lights up all the dash and stuff.
I got a fault code I believe come up - it was 24128
Can anybody tell me what this is please?
Any help appreciated
Rory.
1991 BMW 525i sport manual, BBTB, Mintex Extreme Pads, Bilstein dampers and Eibach springs,Viper2 chip, //M5 Replica.
Well you are getting there. Just need to go back and try again. The fault codes are only 4 digits and all start with one. I have a nice PDF on fault codes including all definitions. PM me and I will email it if you want it is only 300KB
or try this
http://www.bmwe34.net/e34main/trouble/engine_codes.htm
525iT
Not your Daddy's wagon
